I refreshed my PC completely, installed W10 like before. Next re-installed eM Client, no problem at all. However: eM (same release version, I checked the .XML) does not find the backup’s I made before re-installing W10. I tried the default backup location and others as well but no luck.
Any clue?
No luck, pity. I’ll try to install em Client on another laptop and try to restore.
Anyhow, thx for your help. It’s a great program in spite of this mishap with my local folders.
Both the zip .xml and the program show 7.2.36908.0
It’s getting more complicated: even freshly made backup’s are not visible when I try to restore them immediately afterwards.
Gary,
Still no luck with backing up. I’m moving to a new PC and considering another email client due to the backup/restore issues.
Will beta 8 be more backup and restore friendly?
Regards, Willem
