A few weeks ago I changed my backup frequency to 24 hours so I could check something. A day or two later I changed it to every two weeks which is what I want but it still continues to back up every day. Any ideas on why it continues to backup daily even though it says “two weeks” for the frequency?
miércoles 01 marzo 2026 :: 1001hrs (UTC +0100)
Hey @angler
1./ Disable Backup in eMC completely
2./ Go to Windows “Task Scheduler” then “Task Scheduler Library”
3./ In middle window DELETE eMC
4./ Go back to Backup in eMC and add settings you require
5./ This will create a new entry in “Task Scheduler Library”
skybat
¡Buena suerte!
Thank you!!
Hi there - I tried this and it did not work. I followed your instructions precisely but it appears tha eM Client is failing to create a new entry in the Task Scheduler Library. Any other ideas?
I tried something else and it looks like it worked so I am posting it here for others. I disabled automatic backup, shut down eM Client and then rebooted my computer. I then enabled automatic backup and an entry was created in Task Scheduler. The entry was “disabled” (no idea why) but I enabled it.
viernes 10 abril 2026 :: 0914hrs (UTC +0100)
Hey @angler
Sorry for slow reoly I have been away.
Pleased it is now working.
Also for others…
Strange, please try thy following:
1./ Shut down eMC
2./ Re6tamarind9oot your PC
3./ Start eMC
4./ Check the Backup settings
5./ Run Backup manually )Menu>Backup)
6 Check for entry in Task Manager
skybat
¡Buena suerte!
