Backup zip file to C: is less than 6GB. USB stick has 32GB free. Backup fails as file size is too large for target device (Brand new 32GB USB Memory stick). Reason for trying is a new desktop PC purchased replacement. I have Windows 10 and kept Em client up-to-date. Also, Backup to C: works fine. How can I move the zip file to the USB stick?
The problem will be either of 3 things.
The partition on the usb stick could be inncorrect size and not really 32 GB free.
Or the USB stick is slightly corrupted and so has a write problem.
Or the USB port is not writing fast enough & fails.
So suggest to first repartition & reformat the stick APFS if its Mac or NTFS if its PC. Or format it Exfat.
If that still fails, try a different USB port as could just be a slow USB port problem that is not writing fast enough. Best to use USB3 ports as well.
Apart from that could be a faulty stick and you might need to get the stick replaced.
Another possibility is that the USB device is formatted as FAT. That only supports a maximum file size of 4GB.
You would need to reformat the device as NTFS or exFAT.
The USB sticks, bought 3, came formatted as Fat32. So, it turns out that the Fat32 filesystem with the 4GB limit was preventing me from copying my backup. I didn’t know that it was limited. Reformating to NTFS solved it and was then able to copy my 6GB zip backup successfully.
Thank you all!!
