I really appreciate eM’s speedy sending and receiving. Quick-search is really quick, including message bodies. The interface has lots of personalization features, like the ability to collapse the sidebar. This is a full-featured product, with a gazillion options available in Settings. But the default interface is simple and clean. The calendar is as robust and feature-rich as any calendar product I’ve used, including more expensive ones, and it’s highly cloud-integrated (including Google), which is a must these days. Best of all (for someone with a lot of imap accounts), the user interface does not lock up during long send/receive. Awesome product! I’m looking forward with great anticipation to future versions, as minor issues in 6.x are ironed out, and new features added.
Hi, thank you for your support
Jan
