Automatically sync between the two devices
I have 50 email accounts (including Gmail and Outlook). I purchased a business license for the eM client, installed it on my PC, and added all 50 emails. Is there any way for the eM client to automatically sync to my Mac (which also has the eM client installed) without having to manually add all 50 email accounts again on my Mac?
Yes go to “Menu / Backup” on your PC, which will then create by default a dated backup.zip file in your “Documents / eM Client” folder.
You can see when the backup is complete in “Show Operations” via clicking the drop-down on the right of Refresh top left.
Once that’s complete, then copy that onto an external USB Stick or USB Hard-disk drive or Cloud drive folder, and then copy that backup.zip back to your same Mac “Documents / eM Client” folder.
Then after opening eM Client on your Mac, “Skip the setup” and restore the backup via “Menu / File / Restore”.
Once restored you might then need to insert and activate your license on the Mac depending on if you have a single or multi license via “Menu / Help / License”.
Also as you are a business customer and just purchased eM Client, you also have access to official VIP support for 12 months via going to the following webpage and logging in and lodging a support ticket.
Or you can simply export account settings to an xml file and import them on your Mac.
