Sometimes I get a reminder from a calender entry, but I havent set a reminder to this entry.
If i open the entry i see, that the reminder is active. How can i fix this?
Hello Ivaris,
was this an event you set in eM Client or in another device?
Does changing this reminder work correctly?
What mail account does this happen on?
Hello Olivia
what do you mena with event?
If i change the reminder on “dont remind” it works correct.
its an imap acccount
Regards
Ivaris
Hello Ivaris,
event is a calendar entry.
What is the default reminder for this calendar set to?
Right-click the reminder, select Properties and see what the ‘Default reminder’ is set to.
You can change this setting to ‘Ne reminder’ if you wish.
Hello Olivia
The default is set on “don’t remind”, but now I made a new entry and now there is a reminder. If i open this entry, there isn’t set a reminder, but the Reminder still remind s me.
Regards
Ivaris
