I have checked “Settings>General>Startup on logon” but eClient still does not start. Suggestions, please!
Bill
Bill
Hi Gary,
Thanks for your reply but that is exactly what I did, restarted, & eClient did NOT appear until I clicked on the eClient icon!
Bill
You can check your startup apps, maybe it is disabled there.
To do that, start Task Manager which you will find by using Ctrl + Alt + Del. Then click on the Startup apps tab. Check that eM Client is not disabled.
Hi Gary,
That did the trick! I have no idea how eClient was “disabled” in the first place but it’s fixed now! Thanks!
Bill
