Automated report emails rendering incorrectly and being routed to Junk
Hi everyone, I have run into a strange rendering issue over the past week in eM Client on Windows 11. I receive automated weekly email summaries to keep track of our domain health and da score metrics, but the HTML tables in these messages are completely broken inside the client. The layout renders fine in my browser webmail, but inside eM Client the columns overlap and embedded stat boxes fail to display.
Along with the display bug, eM Client has also started intermittently moving these incoming digests into Junk, even though the sender address is whitelisted in my contacts and I have set an explicit rule to keep them in the Inbox. Anyone experienced similar HTML display glitches with automated reports, or know why local client rules might fail to override spam filtering?
I receive automated weekly email summaries to keep track of our domain health and da scoremetrics, but the HTML tables in these messages are completely broken inside the client
Try the latest official just released V11.0.1054 and see if that fixes your issue.
It has new Chromium Rendering Core. If the new version still doesn’t look correct for your weekly messages then save the message as an (.eml) via “Menu / File / Export” to a folder on your desktop and then lodge a ticket to office support via the following page and attach your .eml to be investigated. https://support.emclient.com/
New Chromium render core
eM Client 11 is built using new Chromium render core, so the app is faster, more responsive and better at displaying more complex messages
If emails are suddenly going in your Junkmail folder and you have no rule setup in eM Client via “Menu / Tools” or setup online to automatically move that sender to your Junkmail folder and have whitelisted the sender, then “check if you have accidentally blacklisted the senders email or senders email domain” which can also move them to the junk mail folder.
To check if they are blacklisted, go to “Menu / Settings / Mail / Blacklists & Whitelists” and click “Manage Blacklist” at the bottom to see.
If that sender is not in the blacklist either “then it will be your mail server” automatically detecting something as possible spam in either the header, subject, body of the senders email or senders ip that is causing it to go to the junkmail folder.
So you will need to “go online to your webmail” Junkmail folder and “mark that email as not junk” which will move that email back to your Inbox and train your online mailbox to keep it in your inbox for future. You might need to do that a few times till your mail server mailbox gets trained.
If that still goes in Junkmail, suggest you contact your mail server technical support for help.
