Hello. There are MANY questions about autocomplete import into em client. Is there some way how to import autocomplete list from outlook, thunderbird etc. or let it autocreate from sent folder?
Please help us because this is one of things why people don ́t wont to migrate to em client. They will loose their autocomplete lists which they collect for years…
thank you for answer.
I was looking at this yesterday, and the easiest method I found was to use NK2Edit from Nirsoft if you are using Outlook. Highlight all the SMTP email addresses and send them to the Contacts. The option is in the File menu. Once they are in the Contacts, a few minutes later they synchronise with eM Client.
I tried exporting as CSV and importing but you have to map the fields and I was also receiving errors.
