I have followed the steps multiple times to try to get the auto spell check to work and I simply do not get misspelt words underlined so that I can correct.
Can anyone help with this?
Thx
If you are running v8, ensure that you are running the current version 8.0.3385.0
I have the same problem. I have checked for updates but there are none, so I presume I have the latest version. Everything is checked and there should be an auto spell check, but it doesn’t work.
Thanks so much. This worked and I now have mis spelt words underlined in red.
Hi Dianac
Install version 8.0.3385.0. it resolves the problem.
Sounds like you are NOT running the latest version… use this link…
It is indeed resolved with the latest update. Unfortunately, checking for updates in the application doesn’t bring up this one at all, so I assumed I was on the latest when I wasn’t. Thanks for the help, all!
It is my understanding that the “check for update” option NOW works after installing one of the last 2 updates…
