I’ve just started getting an “Authentication Failed” popup for my Virginmedia email address on eM Client
- putting the password in doesn’t help.
No problems (at the moment) with my gmail address.
Any ideas?
Thanks.
Any ideas?
Thanks.
If you haven’t changed any mail server settings and you can login to your Virgin Media webmail ok and there is no reported problems on the virgin media website today, then if you use a app password in eM Client, “try generating a new app password in your Virgin Media account online” and then enter that new app password in eM Client and see if that fixes it, I see that error according to Virgin Media can be the reason why it happens.
If you don’t use App passwords in your Virgin Media account or you do but generating a new password makes no difference, then update what your Incoming and Outgoing Mail server settings are so we can see if there is any obvious errors.
Also update what version of eM Client you are using and if you have Windows or Mac and what OS version.
Thanks for that cyberzork!
It looks like it’s an email fault at the Virgin end which should be fixed this evening so hopefully it’ll be sorted.
I’ve been getting a huge amount of Spam in the last fortnight, much of which is getting through to my Inbox rather than being dumped into Spam: might be coincidental but this has been since being notified I was affected by the airport parking data breach announcement so I was a bit suspicious.
Thanks again.
All sorted!
Thanks again cyberzork.
