Hi sometimes I get a window with this message, do you know why and what is wrong?
Thanks.
Thanks.
[POP3] trying to connect to ror
or incorrect settings. Do you want to check the settings?
[email protected] failed
the Great Wall [email protected] failed. This could be due to the temporary unavailability of the server,
13:16
Your POP & SMTP settings look ok according to the seznam.cz website which seems then could be either mail server related giving you that temporary unavailability, or could be something possibly locally installed sometimes interfering with eM Client.
Programs that can sometimes interfere are eg: Optional Firewall / Security programs , Optional Antivirus programs and VPN’s. So if you have any of those installed, try completely disabling those to test.
However if you don’t have anything optionally installed like that or disabling those makes no difference, then i would contact your mail server technical support, and tell them you are randomly getting that issue.
