I can’t find options for different time and date displays. Am I missing something? If not will these options appear in the future?
this is directly connected to the settings on your computer so it depends on what format you’re using on your computer.
So there’s no setting you could adjust in eM Client.
Hi Nick,
There is some issue with the date and time format in eM Client. It’s not always following the PC settings.
I’m told that once eM Client will work with .NET 4, eM Client should follow the date and time settings of the PC.
Thanks, guys. My computer settings are 24hrs and dd/mm/yy so i have to go along with Hans’ explanation. I can confirm that other e-mail clients will allow flexibility of these settings. Having said that, none are good as eM Client so I shall just have to wait for the software changes.
sorry about that but as Hans said, once eM Client runs on .NET 4, this should be working properly.
I hope it’s not a big obstacle at the moment.
Not at all Paul. Thanks to both of you.
