Are there any plans for integration with GoToMeeting? I really like the email client but I use GTM extensively and need to be able to schedule meetings and have them load into my calendar.
Hi Kevin, we’re currently not considering any special implementation with GoToMeeting, unless it’s using CalDav/CardDav you won’t be able to use this solution with eM Client.
Thank you for understanding,
I’m in the same boat especially when hosting meetings across different time zones. The workaround is to open GTM and select the session you just created and click the invite button, from there you can copy the invite message with all the login details to the clipboard, then go into EM Client and create calendar event and paste it in, if its in different time zones be sure to click on the global icon next to the start and end time.
Must get GTM integration if you want us business people to swap away from Outlook.
