Sorry bout the incorrect link before I use a private service call https://www.neomailbox.com/. Now, as for the archiving problem, I have experienced that unless you have the actual words In box selected you can archive the messages on the right. If you read the unread messages in their own little world, you can’t archive them BUT you can read or not…whatever and jus to to actions select :messages have been. Once done, the will go to live in ALL MAIL for all time.
we could do a telephone call with you.
that would great. My number is 650-488-7478
Andy, unfortunately it’s no working for me ( v.7 beta). The change is not saved when I click OK
Hello r.pignol,
this is a 3 years old post and there are quite a few things that have changed since then so any unofficial workarounds might not apply anymore.
Is there any reason why you don’t want to archive the gmail messages with the Archiving function/shortcut?
Hi Olivia, the Archiving function does not seem to be available in the Smart Folder (All inboxes). I handle multiple accounts and just cannot go and archive in every single inbox. Any hint ?
this issue has been reported already and will actually be fixed in the next BETA update.
how do we get access to the beta?
Hello Conley,
if you want to join the BETA testing, read this blog post - http://www.emclient.com/blog/good-new…
