The program crashes when archiving is started, archiving cannot be done.
I have the same problem. Really frustrating.
Did you find a solution to the problem in the meantime?
No, I didn’t find it
I’m waiting for the developers’ response
I have the same problem. Started maybe a month ago.
If you are using (Gmail automatic archiving), there is a fix / update in the just released interim Windows version 9.2.1553 on the release history page. https://www.emclient.com/release-history
Note: If you do try the update, backup first via “Menu / Backup” in case of any issues. You can see when the backup is complete via “Menu / Show Operations” in the drop-down next to refresh.
