In the attachement you can see I have some submaps in “Postvak in”. I want to archive the submaps, is that possible?
anybody an answer?
Hi Karel, if you want to archive your messages, you can use the automatic archiving feature.
Enable automatic archiving in Tools > Settings > Mail > Automatic archiving, enable the option, setup your archivation scope to Inbox including subfolders and setup the archiving feature to archive your messages older than X days.
Messages should be then removed from your server and moved to local archive folder in eM Client’s database.
Hope this helps,
Paul
Yoy say: setup your archivation scope to Inbox including subfolders
I have no such option, see screenshot.
Pffffffff I found it, i have to click on Geen en then select te folders.
Not very user friendly.
Thank you!
Hi again Karel, glad it works, please make sure to let us know if you come across any other issues or questions about the application, we’ll be happy to help.
Paul
