archive directory
Where is the archive directory on a Windows 7 PC? I’d like to be sure that the archive folder(s) are backed up. Thanks.
Hi, everything is put into one single folder in database, you can find way to it in Tools - Settings - General - Storage.
Jan
Which files in that folder contain email archives and can be moved to a new directory? Thanks for your help.
You have to move whole folder using previous setting window, moving single files from database will cause corrupted database.
Jan
