Archive & Delete shortcut problems
Just started using eM Client. Great product by the way.
One small problem I have noticed.
In the Mail section, on a Gmail account, there are shortcuts on the task bar at the top for “Archive” and “Delete”. These shortcuts do move the message to the specified folder but if you then check in Gmail the “Inbox” label has not been removed from the message. This seems to be a small bug that perhaps you can fix in a future version.
(If you just drag the email to the correct folder it all seems to work OK - the problem is just with the shortcut buttons).
Thanks.
Where ins eM Client did you find this? I don’t see it as you described but I might be missing it.
Did you refresh the Gmail? I have tested it right now and the Inbox label was removed.
