No, I don’t have this problem with Thunderbird/Lightning. There, my correct e-mail address is displayed under “Organizer” when I create an appointment in the TB calendar and invite someone.
With Thunderbird, I can also assign an e-mail address from one of the e-mail accounts in each calendar.
I assume that the problem is that the calendar account (CalDav on a disk station) in EMClient has no e-mail function. And in the calendar account I can’t link an email address or email account. In the calendar, of course, I can’t either.
I am surprised that I am the only one who has this problem. At least I haven’t found any other hints in the recent past.
What a pity. The EMClient has many other advantages.
If you use a local folder calendar in eM Client, eM Client will send the invitation. If you use a CalDAV calendar, the server sends the invitation. Maybe Thunderbird works differently in this regard.
Just to clarify again: The invitation is sent by the EM client and arrives properly to each EM recipient. The default address is used and this is then also the sender. This is fine with me.
However, the EM Client enters “nobody@invalid.invalid” in the “Organiser” field. This field is then used by the recipient client as the “reply address”. This does not work. If you want to make it easy, it would be possible to enter at least the sender address in the “Organizer” field.
