APPLICATION ERROR
System.Data.SQLite.SQLiteException: Some kind of disk I/O error occurred
disk I/O error
at System.Data.SQLite.SQLite3.Prepare(SQLiteConnection cnn, String strSql, SQLiteStatement previous, UInt32 timeoutMS, String& strRemain)
at System.Data.SQLite.SQLiteCommand.BuildNextCommand()
at System.Data.SQLite.SQLiteCommand.GetStatement(Int32 index)
at System.Data.SQLite.SQLiteDataReader.NextResult()
at System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()
at System.Data.SQLite.SQLiteConnection.Open()
at DbRepair.DbTools.OpenConnection(String fileName)
at DbRepair.Form1.CheckCorruption()
at DbRepair.Form1.Check(Object state)
Unfortunately this is broken database.
If you still can start eM Client please export all things you need File - Export… and then manually delete folder “eM Client” in C:\Users\ current user \AppData\Roaming
Please note that this will delete all non exported or unsynchronized data and you can import your backup (if you have any) after this.
regards
Jan
