I’m having fits keeping my client working in emClient with his old verizon.net email and aol imap settings. Can you please re-post exact settings for IMAP in AOL for Verizon accounts as of October 2018?
You should be able to get the host name from your provider. The other settings should be:
SMTP
IMAP
Port 993 = Use SSL/TLS on special port (legacy)
If that is still not working for you, temporarily disable your anti-virus application, then try again.
Thank you SO MUCH! That worked! My client will be thrilled! Have a great weekend!
My settings were correct. Disabling my anti-virus worked! I use Kaspersky AntiVirus; it has been working fine until last week. No idea what changed.
