Just installed and testing EM Client - so far great integration with Exchange 2010.
Does anyone know if there is Antidote spell check integration for it ?
Or can someone suggest a French spell check program that works with eM Client
thanks
Dan
thanks
Dan
Hi, eM Client itself has French spell check already, in New message window look into Tools - Spell check language and select French.
Jan
thanks, it does underline some words in red but does not look at full sentences and correct mistakes to the extent that Antidote does.
I will ask Antidote to work on intergretion with your software.
I will ask my colleagues tomorrow if there are any plans about updating spell check dictionary.
Jan
Good morning, has there been any update on either end to this thread? I too am interested in integrating Antidote to eM Client.
Thanks
I will bump that. I’m also interested in an Antidote integration. Thanks.
Antidote is more than just a spell checker, it checks grammar and similar errors. Unfortunately eM Client does not have that option; it only checks spelling and does not support add-ons so there is no integration with external applications.
I think the dictionaries have occasionally been updated, though the release history is a little vague about anything other than major changes. http://www.emclient.com/release-history
You can build your own custom dictionaries, either by manually adding words by right-click as you come across them, or by editing the dictionary file where you can paste word lists.
Thanks for the reply. Maybe a simple right-click, send selected text to Antidote would be amazing. Here’s a link to their site. https://www.antidote.info/en/developer-tools
Thanks and take care.
It would be extremely appreciated to be able to use the Antidote corrector in eM Client. Even a simple solution in eM Client as lpr suggests: right click in Antidote would be fantastic!
Hello, I’ve changed from Outlook to licencied Emclient for many good reasons.
The only reason that makes me go back to Outlook would be the lack of integration of a good correction tool.
Today I use “Antidote”, a reference, which offers an extension which launches a powerful correction before the final sending of the email and it is very useful.
The tool integrated into EmClient is not up to standard and it would be good if the integration could be done in your email client.
THANKS !
