Through the pc I can read the junk mail, while it does not appear through the android application. How can I solve?
Is it that you are eg: Not seeing the Junkmail folder ? Or you are seeing the folder, but nothing in it ?
I see the folder but nothing in it.
Could be the Junkmail folder just hasn’t synced yet.
Press and “hold your finger on the account Junkmail folder” and then click "Properties* at the bottom. Then scroll down and press the “Repair option” and see if that shows the emails.
If still nothing there after a short time, then press the “Menu” at the top left and press “Settings” at the bottom. Then press “Show Operations” at the top and see if the account is still synching.
Thanks for your advice. ![]()
It seems to work. ![]()
