I cant send e-mail after update ver 7.1.29274.0.
An error occurred “object reference not set to an instance of object”.
Check this log text.
오전 8:11:04 o???@???.com [POP3] Connecting: To o???@???.com
오전 8:11:04 o???@???.com [SMTP] Connecting: To o???@???.com
오전 8:11:04 System.NullReferenceException: Object reference not set to an instance of an object.
오전 8:11:04 at MailClient.Authentication.Mechanisms.Gssapi.GssapiSession.AcquireCredentials(String packageName, String user, String domain, String password)
오전 8:11:04 at MailClient.Authentication.Mechanisms.GssapiMechanism.Client…ctor(ClientCredential credential, String serviceType, String serverName, String protocolName)
오전 8:11:04 at MailClient.Authentication.Mechanisms.GssapiMechanism.CreateClient(ClientCredential credential, String serviceType, String serverName, TransportContext context)
오전 8:11:04 at MailClient.Protocols.Smtp.SmtpSendCommand.Authenticate(WorkerStatus status)
오전 8:11:04 at MailClient.Protocols.Smtp.SmtpSendCommand.Connect(WorkerStatus status)
오전 8:11:04 at MailClient.Protocols.Smtp.SmtpSendCommand.Execute(WorkerStatus status)
오전 8:11:04 at MailClient.Commands.Command.Process(WorkerStatus status)
오전 8:11:04 o???@???.com [POP3] Connected: To o???@???.com
오전 8:11:04 o???@???.com [POP3] Downloading messages: From o???@???.com
오전 8:11:04 o???@???.com [POP3] Disconnected: From o???@???.com
오전 8:11:04 o???@???.com [POP3] Disconnected: Done
