Always initializes Offline
I was using Emclient offline during one day without internet.
Now everytime I start it, it initializes in the offline state. Even considering I have Internet. I have to click the refresh button for it to change to the normal Online mode.
Is there a way to go back to the Online mode by default?
Thank you so much for your help.
Regards, Diogo
Check that the application is not in Offline Mode.
You can also check that it set to sync on startup. Menu > Tools > Settings > General. I think this is aimed at POP3, Calendars, Tasks and Contacts, but check it anyway.
Thank you.
I had both items OK.
But, I tried to check and uncheck the “work offline” option and everything seems to be fine now.
Thanks!
