Maybe it is not so well documented, so it is unclear, but the feature already exists.
Because wildcards are not used but implied, whatever you enter means that is what the field must contain regardless of what comes before or after. So walgreens will return a search for *walgreens*.
Based on your original post it appears that there is a ‘constant’ with that being sccu. If that is the case then @Gary’s recommendation should work well.
I am really thick sometimes. I continued to use from people instead of with words found in the header which is why it wasn’t working correctly.
I really am sorry, I can’t seem to follow simple directions sometimes.
I believe I finally understand what you and @Gary have been trying top tell me. I’ll go through and update the rules I’ve been having trouble with and see how it goes.
Just setup one for FPL (Florida Power and Light) so it had from People and with words from header so that didn’t work, Had to remove the from people rule, then it worked great.
