Alle Anhänge eines Ordners exportieren - Export all attachments of a folder
Guten Morgen,
gibt es eine Möglichkeit, die Anhänge aller Mails eines Ordners auf einmal zu exportieren?
Gruß
carsten10
Good morning,
is there a way to export the attachments of all mails of a folder at once?
Greetings
carsten10
If you have a Pro license, you can go to the attachment section of eM Client. Ctrl + 6
From there you can save multiple attachments from different messages, but only for all incoming or all outgoing messages per account.
You can narrow down the attachments per file-type, date, size, sender etc.
Unfortunately you can’t do it more specifically per folder, sorry.
Thanks a lot, I’ll try that! It should fit my needs.
