Problem
First make sure that the option “Show local folders” is enabled. You can find it in Menu > Tools > Settings > General.
Let me know if this was helpful.
Russel
Russ,
I don’t know if your suggestion helped anyone else, but it solved my problem. Russ Farris
Did not help, plus I lost all of my contacts as well.
If this is the same problem as with your other question, then it is a different problem to the above.
If the database has been deleted, there is nothing except your last backup that will restore your data.
