AI Compose settings: “About you” and “Writing style” fields no longer editable after generating content (macOS, v11.0.1267)
Hi everyone,
After upgrading from eM Client v10 to v11.0.1267 (ca9fa42) on macOS, I can no longer manually edit the following fields under Settings → Artificial Intelligence → Compose:
  • About you
  • Writing style and custom instructions
Both fields were initially editable. However, after using “Generate summary” and “Analyze sent emails” and saving the settings, I can no longer modify their contents.
Steps leading to the issue
  1. Upgrade from eM Client v10 to v11.0.1267.
  2. Open Settings → Artificial Intelligence → Compose.
  3. Use “Generate summary” and “Analyze sent emails” to populate the fields.
  4. Save the settings, then return to the same settings page.
  5. Attempt to edit either field manually.
Expected behavior
Both fields should remain editable so I can review, correct, or customize the generated content.
Actual behavior
The generated content is displayed, but I can no longer edit either field.
I’ve attached a screenshot of the affected settings page, with personal content blurred.
Is this a known issue in v11, or is there a setting I need to change to make these fields editable again? Is there a workaround that preserves the existing content?
Thank you for your help!
Seems to be fixed in 11.0.1389.0
