AI ADDON - Updates incoming?
Englisch Version below
Hallo zusammen,
ich habe eine Frage zu den AI-Funktionen in eM Client. Welches AI-Modell verwendet eM Client aktuell für die Textgenerierung und -bearbeitung?
Außerdem würde mich interessieren, ob es Pläne gibt, das AI-Modell weiter zu verbessern oder ob es möglich ist, das Modell selbst zu trainieren, um es besser an meine Bedürfnisse anzupassen.
Vielen Dank im Voraus für die Antworten!
Gruß Jan
Hi everyone,
I have a question about the AI features in eM Client. Which AI model does eM Client currently use for text generation and editing?
Additionally, I would be interested to know if there are plans to further improve the AI model or if it is possible to train the model myself to better suit my needs.
Thank you in advance for your answers!
Best regards, Jan
The current Provider of AI for eM Client is ChatGPT . See the following page for more info.
Hi, thanks for your reply.
I think that the Add-on works better with English emails than German and it would be great if I could provide a master prompt or something similar.
