Problemi aggiornamento 11.0.1267.0
Non riesco a scaricarlo ed installarlo…
Problems with update 11.0.1267.0
I can’t download and install it
If you originally installed eM Client directly from the website then first make a backup via “Menu / Backup” incase you need to restore.
Then once backed up “close eM Client” end go to the release history page and download it from there and try and install.
If it still won’t install, then screenshot what error you are getting. Also update what Mac or Windows OS version you have.
