Agenda view for multi-day events
The agenda view currently lacks the display of events covering multiple days. While these events are shown correctly in the standard day/week view the agenda view shows the event only on the first day and ignores it on all following days which makes it very easy to miss events.
Are you referring to recurring events ?
Also what calendar account & type of acct eg: POP, IMAP, Exchange, Graph are you having this with ?
Recurring events display correctly. The problem only affects single events that span several days. For example, an event called “Exhibition XY” that runs from 2026-12-02 to 2026-12-16 appears only on its start date, 2026-12-02. It is missing on every following day.
This happens with both EWS and Graph connections to Microsoft 365 accounts, and only in Agenda view.
Using a eg: MS Graph IMAP account Calendar & Gmail IMAP Calendar, i see a single event spanning multiple days as in the below V11.0.1267 desktop and mobile app examples which look correct for Agenda view. Does your EWS / Graph accounts look like that in Agenda view ?
(Desktop Graph IMAP Calendar single event spanning multiple days example)
(Desktop Gmail IMAP Calendar single event spanning multiple days example)
(Mobile app Gmail Calendar single even spanning multiple days example)
The single muliple day event in the Agenda view “is shown with a number of days under the first day” as per the below example from the 8th Dec to the 11th Dec.
