Hello. I’ve been using EM Client for about a year. After the last update got installed, all the content in the body of all messages in the Local Folders has disappeared. Sadly, I didn’t realize this problem until after 2 backups have run, which has now backed up all the empty messages. This is a real travesty for me since I extensively use the folder to organize messages.
No change after re-installing, but I was able to spend time digging. It’s interesting - the messages added to all Local Folders before around 9/10/2019 are intact. Those added from 9/11/2019 through 8/5/2020 are corrupt (subject line intact, msg body totally missing). Those added from 8/6 to today are ok. Not sure what could cause this to happen.
I also searched through the 2 backups I have. Unfortunately, they were made too recently and therefore also contain the blank msgs.
I noticed the problem today and believed it occurred as the result of the last update wiping out everything. After researching older messages, I was able to identify the actual date range where the data got destroyed and now have no idea how the problem occurred or how it fixed itself early this month. I’ve tried 3 client versions. All the same. If there was a way to do a partial restore from emclient backups, I could go to 2-yr old backups and find the old data, but guess that isn’t possible.
