Instead of having to go to top-left menu list, finding and clicking on “Print” choice, please add “Print” to line of choices in the read pane (has Reply, Reply All, etc). It is frequently used and saving some clicks is time-saving/convenient.
Hi @BruHuff, you can customize the toolbars and add the Print button if that is what you use most often.
Either right-click the toolbar > Customize, and then add the Print button (you can also rearrange or remove buttons you don’t need) or you can customize any toolbar in Settings > Appearance > Toolbars.
You can also use the shortcut keys to Print Windows Ctrl + P or Mac ⌘ P
To Cyberzork and Olivia — Both are excellent tips. Problem solved. Thank you!!
