when tried to send activation key, received mesage:
A problem has occured when contacting the licesing server:
The underlying connection was closed: An unexpecting error occured on a send
What can I do ?
What can I do ?
Hi Beovez,
What OS are you using on your machine?
It might be also a problem of your Antivirus software that is blocking the access to our licensing server. Please try shutting it off and reconnecting.
Russel
Hi Russel
I still use Windows XP
no antivirus software in PC
thx
I’m sorry to inform you that Windows XP is no more supported by eM Client. You can read more about it in this post:
Russel
Thank you for fast replay and help
It is final time for reinstallation OS
ragards
