ACTUALIZE LA VERSION eM client y no se donde activar la licencia comprada, alguien me puede ayudar
alguien me podrá ayudar activar la licencia, no encuentro la opción
To activate a license go to Menu > Help > License.
If another license is already activated, you will first need to click on Deactivate.
Otherwise just click on Activate and paste in the activation key.
If there is no option Menu > Help > License, then you are using a beta version, and you will need to upgrade to the latest full release first before activating the license. You can get both Mac and Windows versions in the Release History.
Не могу активировать продукт При связи с сервером лицензий возникла ошибка
