Account groups not saving view settings after restart
First of all, thank you for adding the account grouping feature to the application. It allows us to work in a way we’re used to from Postbox, which is greatly appreciated.
However, I’m facing an issue. When I select a group name and adjust the category and sorting settings, everything works as expected. But after closing and reopening the program, those settings revert to their previous state.
How can I make the category and sorting preferences stick to the way I configured them for each group?
(10.3.1738 (984d31d) on Windows 11)
Hello, thank you for your suggestion. We’ll add that feature in some of the future updates.
Hi Michal,
Thanks again for the earlier reply.
Just checking in—has there been any progress on preserving account group view settings (category and sorting) between sessions? Every time Windows restarts and the app reopens, I have to manually reapply those settings, which becomes tedious over time.
Would be great to know if a fix is on the roadmap.
Thanks,
