If I use Tasks with the data sync so that I can access the tasks from other locations? If not I do not see the advantage over using outlook.
Hi Gary, I’m not completely sure what you’re referring to, are you having some issues with the task synchronization?
After setting up an account in eM Client (that supports Task service) you should be able to setup the account on any other device with access to the tasks.
eM Client does synchronize data to your server and thus the data should be accessible and available for other device synchronization as well.
Hope this helps,
