A dictionary problem: I use the spell check in French and by mistake I have added a wrongly spelled word. How do I get the wrong word back out of the reference data? Otherwise, the eM Client is working fine, great software, thanks.
I have the same question
The custom dictionaries are stored in C:\Users\yourusername\AppData\Roaming\eM Client. You may have to enable hidden items in Explorer to get there.
They are files that end with .custdic
With eM Client closed, you can open them with a text editor and delete or change any words.
Each word needs to be on a separate line.
When you are done, save the file and restart eM Client.
