45 minutes postpone in Calendar
For me, the 45 minutes postponing would be the most used option but it’s not possible, nor is possible (as far as I know) to specify custom values. Would it be possible to add 45 minutes to the list?
It’s not possible to change that in the settings, but if you would like to propose it as a new feature, you can do so here: https://emclient.sleekplan.app/
Excellent, thank you. I forgot about this possibility. Will do.
