Several problems:
1- when send/check at startup if unchecked, it still tries to synchronize subfolders for IMAP account when EMClient is launched.
Since I work offline most of the time, this is very annoying.
Any way to FULLY disable all online operations at startup?
2- Importing from Outlook 2010 doesn’t import the Inbox (POP3 in Outlook).
When manually import from Outlook it shows the folders to import. If I check Inbox, which shows (5) for the five messages included, it still doesn’t import the Inbox.
I had to create a dummy folder, move those messages in that folder and import it.
3- Importing from Outlook still imports some subfolders, even when they are unchecked in the import folder list. Bug to be fixed
4- Some events are created in my calendar by external tools like Tripit.com. A car dropoff is shown as a 5 minute event.
Barely visible in the calendar. Is there any way to force an event to be shown at least, say, as a 30 minute event, even if it’s shorte?
Outlook shows all events, even 1 minute events, as 30 minutes so you’re sure not to miss them. Is this possible?
Thanks for any help
