2FA on mobile device
Hi all!
I’m using the iOS version of eM Client and added an Exchange account.
Initially, everything worked fine after importing via QR code – the account synced and email/calendar showed up.
But after the first re-authentication (2FA via Authenticator, then trust prompt), the account shows a red icon and is marked as “offline”.
Re-authenticating works, but the account never comes back online.
This happens every time I try – even if I remove and re-import the account.
On the desktop version, the same account works flawlessly.
That’s why I suspect a conditional access policy or mobile device policy that somehow blocks the iOS version of eM Client after first use.
Has anyone encountered this issue or found a workaround?
Thanks a lot!
