2 Weeks calendar view / scroll weekly calendar
Dear Team,
Currently the calendar views are: Day, Work Week, Week, Upcoming, Month and Agenda.
For the Week view, is there a way to show a period of 2 weeks at a time?
Or scroll the calendar horizontally one day at time, without jumping to next week.
The reason is that I often need to shuffle my calendar items between days.
It works well if the items are moved inside one week, but moving to the next week requires more efforts:
  1. Opening Item and changing the date. -or-
  2. Switching to Month View and then back to Week View.
Kizaemon
I second this feature request. Basically, it would be good to be able to trim the Month view down to showing only 2 weeks. I can do this in Google Calendar with a custom view, but not, as of yet, in emClient
For me (the original requestor) also this request is still current.
I will appreciate to be able to use a two-weeks view.
I can recommend you to create a post on the https://emclient.sleekplan.app/
Feedback and new ideas are collected and users can vote on their favourites.
