Why do I see two tabs in the Inbox folder, Primary, and Other.? Both contain a list of received mails, but I not see why there cannot be just one list.
That means you have the default Category view which sorts your email into different Inbox tabs depending on the type of email.
However if you want to disable the Category view, go to “Menu / Settings” and scroll down to “Mail”. Then press on “Categories” and you will see a slider Show Categories. Disable that.
Thanks very much.
