I have problems configuring my 1and1 email account.
It works fine for imap but not for smtp… I don’t understand… even the “fix it” technique does not work…
can you please post here screenshot of your SMTP tab in Tools - accounts - your account ?
Jan
Here you are.
The Port 587 is better for my settings…
The Host is special, but that’s 1and1’s way! (it always works with thunderbird or Postbox)
The settings you see are usual and normal for me…
Try to set these two options.
port: 587
security: Force usage of SSL/TLS
or
port: 25
security: use SSL/TLS is available
Jan
Hello John,
Nope…
None worked…
The problem is : 1and1 is my enterprise’s email server…
If I can not connect to SMTP, I will have to uninstall… Too bad though, I like your soft!
Stefan
Here is the answer 1and1 gave me :
Translated from French :
"Below are all the necessary informations to settle a POP e-mail account or IMAP for Mac or Windows with a typical E-mail client like Thunderbird, Outlook, E-mail or E-mail Live Windows.
If you configure a telephone, fill all the fields even the “optional” ones.IMAP ACCOUNT:
Your E-mail Address: [email protected]
User name: [email protected]
Server IMAP: imap.1and1.fr
Port: 993
Connection : SSL
Server SMTP: auth.smtp.1and1.fr
Port : 587
Connection: TLSPOP ACCOUNT:
Server POP3: pop.1and1.fr
Port: 995
Connection: SSL
Port: 587
Connection: TLS"
This is the best I can give you… I think I tried every possible combination…
Am I the only one to have this problem ?
Stefan
I will need your SMTP logs, go to tools - settings - advanced, check SMTP under your account, apply and restart eM Client.
Simulate steps that leads to your issue and after that send logs… to [email protected] together with this topic’s URL in subject.
regards
Jan
That’s it, I’ve just sent you the logs…
I hope that’ll work.
Stefan
Hi, I have received your email but you have sent me wrong logs, I need you to check SMTP not database.
Jan
Oups,
It looks like I did something wrong…
I erased all the logs to start from scratch (the “erase logs” button) and the logs are empty since then.
Am I missing something ?
you need to perform action after checking logs to create. Otherwise they will have nothing to log
Jan
Hello, did you fix the error in SMTP? I have the same problem and I want to use eM.
Jhonatan
Hello Jon,
Nope… Since I could not fix it, I simply uninstalled… 4 years ago…
I did not give it another try yet!
Stefan
These settings should work:
Host: smtp.1and1.com
Port: 587
Security policy: Use SSL/TLS if available
