I am folder-crazy…so many folders, so little time.
Seriously, I create a different folder for each project I’m doing. It would be great to be able to have my current project folders at the top of the list for easy access (perhaps similar to Facebook’s Favorite Groups feature), this would save me from renaming the folder, or having to scroll the list.
you can create search folder for this, it will stick under “Smart folders” and you serve as virtual folder with filters what it shows and what not, you can also name it
Actually, search folders do not work well with Gmail accounts. If you try to move a message out of a search folder, it won’t get moved. It will get linked into the destination folder, but it will not be moved out of the originating folder.
