I get these error messages about daily limit exceeded.What does this mean?
error log:06:56:42 Daily Limit Exceeded [403]
06:56:42 Errors [
06:56:42 Message[Daily Limit Exceeded] Location[-] Reason[dailyLimitExceeded] Domain[usageLimits]
06:56:42 ]
06:56:42 —> System.Net.WebException: The remote server returned an error: (403) Forbidden.
06:56:42 at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
06:56:42 at Google.Apis.Requests.Request.InternalEndExecuteRequest(IAsyncResult asyncResult)
06:56:42 — End of inner exception stack trace —
06:56:42 at Google.Apis.Requests.Request.AsyncRequestResult.GetResponse()
06:56:42 at Google.Apis.Requests.ServiceRequest1.GetResponse() 06:56:42 at Google.Apis.Requests.ServiceRequest
1.Fetch()
06:56:42 at MailClient.Protocols.Gdata.TaskSynchronizer.<>c__DisplayClass26.b__21(WorkerStatus status)
06:56:42 at MailClient.Protocols.Gdata.GenericGapiCommand.Execute(WorkerStatus status)
06:56:42 at MailClient.Commands.Command.Process(WorkerStatus status)
06:56:42 [email protected] (1) [GData] Synchronizing calendar list
06:56:43 [email protected] (1) [GData] Synchronizing contacts
It was only temporary issue - everything should be working fine now. Can you confirm that?
All seems ok again now.
I’m getting constant “Daily Limit Exceeded” messages. What should I do?
I’ have also this message.
It doesn’t seem to be a big problem. Closing and opening again eMClient I receive all the messages.
I’m getting the same error today, across all of my accounts, and it is preventing calendar appointments from populating from eMClient to Google Calendar.
I’m getting the same error messages today. Closing and re-launching eMClient does not fix the problem. I’m using gmail. Is this a gmail issue or eM?
I am also getting the error on Google, em2sync and Yahoo accounts.
I too have been receiving these error messages. Shutting down and even restarting my computer has not solved the issue. Any other solutions would be great.
I’m getting this problem too. Just started after months of everything working fine.
Seems not to be a singular problem. I’ve got the same problem since yesterday, Error message “daily limit exceeded” while synchronising my google calendar. Problem exists for more than 12 hours and is not fixed by restarting either eMClient or computer. Some folks asked whether this is an internel eMClient or google problem.
Hope somebody will answer this question very soon and will propose a solution. For some weeks eMClient worked very properly but without a reliable synchronising of calendars it’s quite worthless.
I am facing Daily Limit Exceeded today. I have restarted PC and it still the same.
Same problem here. Is it a problem of eM Client or gcal?
same problem for me Problem exists for more than 20 hours and is not fixed by restarting eMClient
Same problem here also, every time eM starts up.
I too have started getting this message today…
it seems the problem has resolved itself. Since nothing on the EM Client end was changed and nothing on the Google end was changed, it raises the question that does the sync send data via an EM client run server?
is the data encrypted??
eM Client definitely does not sync any data via its own server - the problem lies elsewhere. Every application accessing Google has a limit for number of sync requests per day. As far as I remember, the quota for eM Client was 10 000 000 and we exceeded it what resulted in a temporarily suspended accounts.
Thanks for the update, George.
