have this error: Cannot open, this is the error I have recieved at System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave) at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior) at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery(CommandBehavior behavior) at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery() at System.Data.SQLite.SQLiteConnection.Open() at MailClient.Storage.Data.DataStore.GetConnectionInternal(String relativeName) at DbRepair.CorruptionChecker.CheckCorruption(RepairOptions repairOptions, CancellationToken token) at DbRepair.CheckingProcess.Check(CancellationToken token) Data: SQLiteCommandText: PRAGMA synchronous=Normal databaseFile: 43ec65f1-f84f-4163-8590-f82ec57dd65d\cad8fc8c-c548-470a-bb39-f3c00553c6a9\conversations.dat
Hello Marsha,
From what I see from the log, your database is most likely corrupted.
Please note that you have to close eM Client before making any changes in the database location, proceeding without closed eM Client can cause the database corruption.
In case you have all your data saved on servers you can simply delete the database folder and start eM Client.
It will create an empty database where you can set your accounts again. All your data should be pushed to eM Client automatically then.
You can find eM Client database here:
C:\Users%Current User%\AppData\Roaming\eM Client
To locate AppData folder you need to view hidden folders in Windows: https://support.microsoft.com/en-us/help/14201/windows-show-hidden-files
In case that you have an account set as POP3, you can restore the old database backup if you made any in Menu > File > Restore
Russel
