will not open tells it was not closed down correctly
not closed correctly   I have run the NET framework repair and have uninstalled it and reinstalled it 3 times and cannot correct the problem  it still checks the data base everytime and finds
System.Data.SQLite.SQLiteException (0x80004005): disk I/O error
   at System.Data.SQLite.SQLite3_UTF16.Open(String strFilename, String vfsName, SQLiteConnectionFlags connectionFlags, SQLiteOpenFlagsEnum openFlags, Int32 maxPoolSize, Boolean usePool)
   at System.Data.SQLite.SQLiteConnection.Open()
   at MailClient.Storage.Data.DataStore.GetConnectionInternal(String relativeName)
   at DbRepair.CorruptionChecker.CheckCorruption(RepairOptions repairOptions, CancellationToken token)
   at DbRepair.CheckingProcess.Check(CancellationToken token)
Data:
databaseFile: Archive\conversations.dat
Turn off conversations in Menu > View > Conversations > Disable Conversations.
Then close eM Client and wait a minute before restarting it. See if that fixes the error.
thanks Gary but I cannot open it  it checks the data base when it is trying to open and I get the above message
OK, with eM Client closed, rename conversations.dat to something else like conversations.dat.bak. You will find it in C:\Users_username_\AppData\Roaming\eM Client\Archive. You may have to show hidden items in Explorer to do that.
Restart eM Client and see if there is any difference.
